Helldivers 2 - Anyone else noticed very high CPU temps?
4 minutes ago, DarkSkela said:Everything CPU related should be totally stock, unless my Mobo (z790 AORUS Elite AX) changes some stuff at BIOS level. But I'm not sure about that.
I have the Elite AX as well. I can't remember if there was anything auto set.
I'm leaving there here for you as some food for thought. It shows what I was talking about earlier with a lot more power for the last few fps in performance.
Being on an air cooler, I'd probably just straight up use Derbauer's settings and set your turbo limits to 90. You could always play with it and find that limit of thermal throttling. Say if 100W keeps you at 95C but gives another frame or two then run that.
I'm not around my computer, but IIRC I'm sitting around 180 or 200W. It's sharing rads with a 4090, but that's with my cooling being a 280mm and a 360mm rad.
