For my application to Appamattox Governer School in Virginia, I need to make a project that people use in their daily lifes. Im making a smart thermostat using a raspberry pi. It will have a screen but i want the screen to switch to a mirror once i make a selection. Is there any screens that can do this? Google nest can.
https://linustechtips.com/topic/1561347-i-need-help/
Are there panel, like these? Probably yes, check aliexpress or alibaba. But the fastest would be by making your own. You just need to use a regular panel and two-way mirror(one-way mirror same thing). Goggle DIY smart mirror. But instead of the actual acrylic, just use two/one way mirror film. So instead of a full size tv, you can try to use a smaller panel. If this is not the one you are looking for, then my apology. But good luck on your application!
https://linustechtips.com/topic/1561347-i-need-help/#findComment-16341961
What if I tell you that the magic trick isn't the screen?
Look it up. this is your homework.
The Declaration of Independence, once the charter of democracy, begins by saying that certain things are self-evident. If we were to trace the history of the American mind from Thomas Jefferson to William James, we should find that fewer and fewer things were self-evident, until at last hardly anything is self-evident. (G. K. Chesterton - Aug. 14 1926 (The Illustrated London News))
https://linustechtips.com/topic/1561347-i-need-help/#findComment-16342776
So you know it's mirror foils?
I don't have a uv-vis at the moment to measure it but:
1. they take out approx. 60% of the brightness -> use a bright LCD!
2. not all wavelengths are equally attenuated/blocked -> design the code in such away that you can load a simple calibration list/array. Nobody cares that you don't have access to a spectrometer to measure it. What counts is that you are aware of this and implemented a solution.
Btw. There are two versions of mirror foils:
1. outside of the window/outdoor
2. inside of the window
These details probably won't be noteworthy for the project.
Hardware for a quick and dirty prototype?
https://github.com/scottbez1/smartknob (roughly $30 in China)
Or buy one of those ESP32 or RP2040 round display devboards.
Good luck. Hope you succeed developing the firmware.
https://linustechtips.com/topic/1561347-i-need-help/#findComment-16343394
thank you!
https://linustechtips.com/topic/1561347-i-need-help/#findComment-16343411
