Can someone help with audio input
Solved by Heats with Nvidia,
As far as i can see, this one is configured for a balanced signal. By the way, its a little weird to see, that there are still new amplifiers with that 1980ies chip out there. My first selfmade amplifier had that chip and that was a while ago.
But its OK, not very powerful, but it does the job.
A quick look into the datasheet and 5min of looking at your photos, tells me, that the pin in the middle is ground, the ones next to it, are the inverted inputs, just connect them to ground, and the outer pins are your two normal inputs. I hope it works, when you connect it that way.
