Molex will just send full voltage, you need to plug them in to your motherboard or a fan controller to have the speed regulated.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/15608-help-with-fan-speed/#findComment-175205
If i use a molex to fan adaptor will the fans run at max rpm?
  i want the fans controlled by the temputer of my computer atomatically
depends on the type of the adapter there are 12V 7V and 5V adapters available.
12V=full speed
7V=low noise
5V=Ultra low noise
To run your fans according to the temperature of the system you need a T-Balancer fan controller.
https://linustechtips.com/topic/15608-help-with-fan-speed/#findComment-175213
Yup, they will run at full speed, but you can buy low noise adapters form Noctua, or make your own with a couple resistors.
Best way to get automatic speed control is to plug the fan into the motherboard.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/15608-help-with-fan-speed/#findComment-175566
