Aio Mounting help, Liquid Freezer III 360
HideOnPepe
Hello, As you all probably know, the radiator is very big on the Arctic Liquid Freezer III, and it doesnt fit in my case that easy (i want to front mount it). So I wanted to ask if I could mount it just like described in the picture. Radiator inside the case, and the fans “outside” the case behind the glass panel.
I am thankful for answers in advance.
Yes, you can even put the whole rad+fans on the outside. It does not NEED to be inside and you'll get better results.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
