Hello All! I have finally worked up enough guts and cash to attempt a first build. I am aiming for a mid level gaming PC in the $US 1,500 range. I have assembled a list of components that I was hoping to get some feedback on in terms of compatibility and performance. Thank you all for your time!
Case:  Cooler Master HAF 932 Advanced - High Air Flow Full Tower Computer Case with USB 3.0 and All-Black Interior http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Motherboard: GIGABYTE GA-Z97X-UD5H LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Graphics CardEVGA SuperClocked 02G-P4-2765-KR GeForce GTX 760 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support w/ EVGA ACX Cooler Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130932
Power SupplyCooler Master V650 – Compact 650W 80 PLUS Gold PSU with Modular Molex/SATA Cables (Haswell/Kaveri Ready) http://www.newegg.com/Product/Product.aspx?Item=N82E16817171093
CPUIntel Core i5-3570 Ivy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 77W Desktop Processor Intel HD Graphics 2500 BX80637i53570 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233
SSD: (for OS and commonly used applications/games):  Crucial M500 240GB SATA 2.5" 7mm (with 9.5mm adapter) Internal Solid State Drive CT240M500SSD1 http://www.newegg.com/Product/Product.aspx?Item=N82E16820148694
Hard Drive: Western Digital WD Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16822136792
Memory: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
Disk Drive: ASUS Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 4MB Cache SATA Blu-ray Burner BW-12B1ST/BLK/G/AS http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252
Operating System: Windows 8.1
Thermal CompoundARCTIC MX-2 (4g) Carbon-Based Thermal Compound, Non-Electricity Conductive, Non-Capacitive http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
Thank you again for taking the time to help a newbie!
https://linustechtips.com/topic/155989-first-ever-build/
For 1500$ you can do much better than a 760
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($223.98 @ SuperBiiz)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($59.99 @ NCIX US)
Motherboard: Asus Z97-K/CSM ATX LGA1150 Motherboard ($129.99 @ Amazon)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($74.99 @ Newegg)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Disk ($119.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.43 @ OutletPC)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($477.99 @ SuperBiiz)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($99.99 @ NCIX US)
Power Supply: SeaSonic 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($88.99 @ SuperBiiz)
Total: $1330.34
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-22 20:51 EDT-0400)
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079196
Are you limited to newegg or are you open to other US shops?
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079209
better use the quote button if you want my help
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($134.99 @ NCIX US)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($118.00 @ Newegg)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($74.99 @ Amazon)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Superclocked ACX Video Card  ($714.99 @ Micro Center)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Total: $1502.85
(Generated by PCPartPicker 2014-05-22 20:54 EDT-0400)
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079212
Total: $1330.34
that brow pc ew also why the 620w?
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079223
Between @CoolBeans & @SAV1OUR damn it's close. I would go with the 780 system option I think although the 780 ti based system is very tempting
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079229
i swear its always like this :P
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079248
dude...780 + z97. am3+ not too bad either, still got a lot of good processing power in both systems
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079263
This is going to be much better for your money. I used all newegg as you did.
http://pcpartpicker.com/p/3P8tg
Btw i5-3570 is not compatible with that motherboard.
still using z87 ew step it up to z97 so he can upgrade cpu if needed
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079274
Hope you like this one :D
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Best Buy)
Motherboard:  Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($228.99 @ SuperBiiz)
Video Card:  Asus Radeon R9 290 4GB DirectCU II Video Card  ($399.99 @ Amazon)
Case:  NZXT H440 (Red/Black) ATX Mid Tower Case  ($119.99 @ NCIX US)
Total: $1509.79
(Generated by PCPartPicker 2014-05-22 21:09 EDT-0400)
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079299
Total: $1502.85
Is AMD as good as Intel? I've heard that Intel is the way to go and to avoid AMD... but then again I am brand new to this.
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079437
amds fine people are just being fan boys and voicing their option because they think that they are the most important person ever
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079451
Total: $1509.79
Will 8GB of RAM be enough for a mid level gaming PC? Also, I had heard that Radon and Intel don't work well together. But I am new to all of this, so I'll trust people that have been doing this for awhile.
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079454
AMD is a better value no question, but unless he's rendering and on a sub $1,000 budget it's not a good choice.  AM3+ is dead and the FX series CPU's do very poorly in single threaded games.  Planetside 2 and WoW will do better on a Pentium G3420 than an FX-8350.  But there is no game where an FX-8350 spanks an I5-4670k.  Sure they trade but the I5 doesn't get destroyed in any game like the FX-8350 does in some scenarios.
i know not in all games but amds still very good for gaming
Specs
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079672
Avoid the HAF 932, 3 words: No Dust Filters.
Yes 8GB is enough, Yes Intel+AMD work together.  But don't get the Asus R9-290.  The only 290's that don't overheat is the Twin Frozr, PCS and Sapphire's lineup.  The Gigabyte and Asus ones use the 780 cooler and it doesn't make proper contact.
The DCUII is a great cooler... And just don't make a statement without fact. :)
"THE RED ARMY"
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2079894
Motherboard:  MSI Z97M Gaming Micro ATX LGA1150 Motherboard  ($169.99 @ Amazon)
Storage:  Kingston HyperX 3K 240GB 2.5" Solid State Disk  ($134.99 @ Adorama)
Case:  Corsair 350D Window MicroATX Mid Tower Case  ($99.99 @ NCIX US)
Total: $1523.87
(Generated by PCPartPicker 2014-05-23 09:30 EDT-0400)
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2081590
No, I was just using them to keep all my parts in one list.
How's this look instead? http://pcpartpicker.com/p/3PRwi
https://linustechtips.com/topic/155989-first-ever-build/#findComment-2085900
