Archer C86 AC1900 or Archer VR2100 AC2100 for home herver?
After a lot of research and trial and error, I finally got it working!
It's not exactly what I originally set out to do, but it's close enough for me.
I bought a TP-Link Archer AX23 Wi-Fi router and a TP-Link LS1005G network switch. I plugged the switch into my ISP gateway, then connected my PC and Wi-Fi router via Ethernet to the switch. I switched the new router to "Access Point" mode and disabled DHCP on it.
Now, the devices on my LAN can ping devices on Wi-Fi, and vice versa - success!
I hosted a simple PHP web server to test if everything was working properly, and sure enough it was.
But there was one big issue - my ISP uses CGNAT, which prevented devices on Wi-Fi from resolving the domain I use for my local server. I fixed that by transferring my domain to Cloudflare and using their proxy, and voila! Now everything is working flawlessly!
