Fans and Headers!!!
Go to solution Solved by Hinjima,
5 minutes ago, Lota_9 said:
Best Buy has it! You think it will fit with my ram and case? Also, does this come with mounting hardware?
The Thermaltake TOUGHAIR 510 has a height of 159.5mm and your case can support AirCoolers up to 180mm so you have plenty of space.
The Thermaltake TOUGHAIR 510 comes with thermal paste and all the mounting hardware required.
It should not be an issue with RAM as its not a massively large cooler and the front fan does not stick out too much 馃檪
No Problemo!
Budget (including currency):聽759
Country:聽 America!!!
Games, programs or workloads that it will be used for:聽Mediocre intensity for gaming (Fortnite, Roblox, Minecraft, and some CAD modeling.)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):聽Alright, I need opinions on the CPU cooler. All I need to know is that if it will cool my CPU to a reasonable temperature. I don't care about the price to performance because I just love the look of the cooler (And I can get it at my local best buy.) I also want to know if it comes with mounting hardware. I also want to know if my motherboard will have enough headers (My case fans have a fan hub that came with the case.)聽聽聽https://pcpartpicker.com/list/M7mCvj
https://linustechtips.com/topic/1559264-fans-and-headers/
All motherboards come with a fan header for the CPU cooler so nothing to worry about there.
Your motherboard has 1 CPU FAN_Header and 5 additional fan headers for case fans or similar 馃檪
The Hyper 212 should be able to cool the 12600k if you only plan on doing gaming but if you are stressing the CPU to 100% I would personaly go with something a bit beefier.
Peerless Assassin SE120 is a strong choice.
Check if your best buy has the Thermaltake TOUGHAIR 510 in stock at your location 馃檪
https://linustechtips.com/topic/1559264-fans-and-headers/#findComment-16327403
https://linustechtips.com/topic/1559264-fans-and-headers/#findComment-16327415
No Problemo!
https://linustechtips.com/topic/1559264-fans-and-headers/#findComment-16327419
