Find cooler by screw spacing 48mm x 48mm (not a PC)
1 hour ago, CodeSailor said:You cant look it up, just pick any single one and zipties it together somehow. => This is what I'm trying to do. But what cooler to use for it? Also this doesn't address the issue of still having to find a cooler that fits enough to be ziptied to the board...
Basically whatever fits and doesnt damage the board. Like people have put a nhd15 on a 1080 before (i think it was that) or a smaller be quiet on a raspberry pi 3 and pretty much machined custom mounting brackets for it to work as well as suppott for the weight. Then for the vrms they used some nvme heatsinks with a shroud over it that a smaller pc fan pushed air into for the gpu onr they did.
1 hour ago, CodeSailor said:They all only partially answers the question, I still kinda hope that someone knows of something that would make reusing components like heatsinks more feasible in practice and reduce/remove the need to make one off custom cooler (mods).
Issue is that simply put once the dimensions or layout shifts of lets say a gpu, motherboard, raspberry pi,... nothing will ever fit again. You cant make something universal if the stuff you want to put it on does not adhere to a standard.
As for getting the data. You are like a super mega ultra niche user. Likr 0.000000000000000000000001% of the usecase for this product if even and any resources wasted on giving you a exact measurements diagram is considered a loss.
Some nicher companies/enthousiast companies/products may list them because they know their product may actually be used for that or they actually care about it but for any of the mass produced ones hell no.
Also once you have set measurements duplication is easier.
Off topic
For your gpu you could opt for a finstack that aligns with thr path of the airflow. Its how all thos controller cards n stuff do it yo get cooled effectively. Would not be surprised if some older cards cooler can be retrofitted with some copper shims and stuff for the vrms
