Need help with upgrade and clearences
Solved by podkall,
Are you focused on aesthetics aswell or would you be fine with using another CPU cooler?
But, you might be able to fit your current one,
I searched the CPU cooler you have on list on pcpartpicker and I looked at builds that use it,
then I found AM5 system, and I found a system that uses the exact same motherboard you plan using,
here's the picture of the case's inside and link to the build: (as you can see the cooler doesn't go over the RAM sticks)
https://pcpartpicker.com/b/QLLPxr
