290X OC'ing Problems
By
ReedSta4
in Troubleshooting
in Troubleshooting
Solved by DoubleY,
You just have bad luck. You didn't get a very good OCing card. Not all cards are capable of OCing good amounts. It's called the Silicon Lottery.
If you really want, you can increase the voltage. But that will only make the card run hotter/louder than it already does.
derekchan ·
1
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
play_circle_filled
Latest From ShortCircuit:
