Budget (including currency):
Country: UK
Games, programs or workloads that it will be used for:
Other details hey so I’m about to start building my pc today and I’m just unsure about how I should update my bios , for context I’m putting a 14700k in a msi z790 edge WiFi board and just want to know can I leave the flash bios till the end once everything is assembled and in the case or do I need to do it before putting the cpu in?
https://linustechtips.com/topic/1558467-flash-bios-help/
Your mobo seems to support 14th gen CPUs out of the box, at least according to the product page. It doesn't seem to support BIOS updates without a CPU installed though.
I'd recommend you build your computer and then, when it works, you can update the BIOS, if that is even necessary.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322549
Oh that’s great because on pc part picker it was saying I may need to update my bios to support the 14 gen cpu
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322551
Although on the actual board box it only says 13 gen?
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322556
That's interesting..
When did you buy your board?
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322561
@Average Nerd it does support BIOS updates without a CPU installed
There is a Bios Flash Button on the backplate, so you're fine either way
"(No need to install CPU and memory)"
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322584
Ok, I didn't see that on the product page, good to know.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1558467-flash-bios-help/#findComment-16322586
