So I'm new to pc building and just built my first one yesterday and my idle Temps seem to be high. I'm using a Ryzen 7 7800x3d and seem to be idling at 55c-60c most of the time. It sometimes sits around 40c-50c. Is this normal or should I be concerned also under load I get up to 80c.
Edit: Temps seem to be at 40-45c now for idle but not going up much when gaming. Highest I've seen is 55c if im not playing cyberpunk. But when playing cyberpunk it's around 60-65c
Edited by jjkmyth
New information
https://linustechtips.com/topic/1558320-idle-temperature/
What cooler are you running, what case are you using, what is your fan setup in said case, and what is the ambient temperature. With a decent dual tower cooler and a ~20C ambient, I'd expect the idle temp to be ~40-50C, the game temp to be mid 60s, and the hottest it'll ever get to be ~80C in something like Cinebench. If your
https://linustechtips.com/topic/1558320-idle-temperature/#findComment-16321736
I'm using a Asus Ryujin iii 360 for the cooler. A msi Gungnir 300r Airflow, the stock fan set up in the case, 3 intake with 1 exhaust and the radiator is set to exhaust because that's what I've seen everyone say to do. Ambient temperature is 24c. When I did a Cinebench run it hit 79c as the hottest and that's normal what it sits at when gaming.
Edited by jjkmyth
New information
https://linustechtips.com/topic/1558320-idle-temperature/#findComment-16321745
Seems normal to me. Note that you simply not doing anything on the PC for a few seconds and true idle are two different things. When saying "idle", take note of CPU activity and unless its sitting in the 1-3% range, its not idling.
That being said, your load temps seems fine so I don't see an issue. Even small actions like opening a window is going to spike temperatures briefly but that's normal and expected. Simply don't focus on Idle temps unless the chip is not performing as it should under a true load.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1558320-idle-temperature/#findComment-16321766
Load temps are gaming or synthetic load?   80c gaming is too high for a 7800X3D.  Did you PBO/CO at all?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1558320-idle-temperature/#findComment-16321777
