1 minute ago, m0narch_0 said:
i have a 3090 24g and a 11700k the gpu never get above 60%usage.
games are running at 100fps at 1920x1080.
iv changed the power plan in windows and the manage 3d settings in control pannel
It doesnt need to run at 100% to be doing all it can with what it has, what is your cpu usage at during this time?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
that's more likely the combination of not realy overloading the GPU and cpu with 1080p resolution... and output beeing badly configured. did you turn vsync off?  what refresh rate is the monitor on? have you tried 4k resolution?
i dont have a 4k monitor. i have a 165hz monitor with vsync off. i use to have a 280hz monitor with gsync. and it was a issue then
7 minutes ago, m0narch_0 said:
im currently play gta 5 maxed settings 1080p at 40%usage 65fps
then it's other things that's limiting your GPU....
and seriously ... you bought a 3090 to play at 1080p?....  that's almost like buying a ferrari V12 engine to run a lawnmover..
try to get a 1440p or 4k monitor.. or atleast that should be next on your upgrade list 😄
That be why. Bad display and GPU combination.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
i was stupid and it was for high refresh rate cs2
the cpu is runing at around 50%
Then you need a faster CPU.
5 minutes ago, m0narch_0 said:
my cpu is locked at 4.6ghz
not boosting
can i fix that?
if CPU is running at 50%.. it's not your problem.. what disks do you have installed?..
i ran my two 2080ti's on a 30 inch dell 3007 monitor at 2600x1600 60hz..forever.. getting a 32 inch 1440p at 240hz monitor made my cards reach it's limits.. 😄
then again i run 2 samsung 960 pro nvme's in raid0 to keep up with any demand..
when specking a system please include the monitor in the consideration..
both 3090 and 4090 are 4k beasts..
not boosting
can i fix that?
Whats your entire system specs?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
1 hour ago, m0narch_0 said:
11700k
That's why.
The generational gaps between 11th, 12th, 13th were substantial, in comparison to something like the 7800x3D even more. 11700k won't maximize an RTX 3090 at 1080p unless you're running ultra ray tracing or such on some newer games.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
Bingo!
Just don't. Maxed out AA and higher resolution scaling will tank your fps(although you can do higher resolution scaling instead of more AA). Also don't worry about not getting 100% gpu utilization in GTA 5.
11700k
You can overclock you cpu for a bit extra performance.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Severe CPU bottleneck on that resolution.
You have three options; platform upgrade, monitor upgrade or simply accepting you have a bottleneck and cope with it.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
