internet on wifi slow, but using a VPN or cable makes it fast again
LouKs
Hi, I have a very weird problem where my laptop on wifi is very slow.
-When connected via cable I can get my full internet apeed
-When on wifi, but connected through cloudflare warp VPN, I can also get my normal speed
-Other devices on my wifi network works normally at full speed. It's just my laptop being weird
-I'm using openWrt on a Redmi ax 6000 (wifi 6) on a mixed mode (2.4 and 5ghz on the same ssid and password)
Does anyone know what is happening and how to solve it? Thanks!
2 hours ago, TomChaai said:
Did you mess with the IP/DNS stuff of the wifi adapter on the laptop?
No, DNS is set to automatic (DHCP), same as all other devices. I do use 1.1.1.1 with fallback to 8.8.8.8 on the router tho.
2 hours ago, LeapFrogMasterRace said:
Are you doing things on the laptop that you are not doing on other devices?
Not really. Just browsing and downloading some stuff here and there.
