case Fan placement question
Solved by TatamiMatt,
5 minutes ago, svenvb said:I have a Magniumgear Neo Qube 2 IM as case (basically a Lian Li O11) so only the rear, sides and top are open.
How do I use my dust filter? It's only on the bottom.
So id go for one of two options then, AIO intake on side panel, bottom intake and top exhaust
Or 6 intakes, side and bottom and AIO as exhaust on top
