my first build
Go to solution Solved by Blasty Blosty,
I would go for something like this - https://nl.pcpartpicker.com/list/NmcVHG
Budget (including currency):  around 1500 euros ( max 2000)
Country: netherlands
Games, programs or workloads that it will be used for: fortite and similar games
i want to game at 1080p 240 hz, but i have no idea what i need to spend more on and what i need to spend less on.
Thanks for the help.
https://linustechtips.com/topic/1556756-my-first-build/
You can get a pretty high end rig :
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€398.95 @ Megekko)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (€49.99 @ Amazon Netherlands)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  (€190.95 @ Megekko)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR5-6000 CL40 Memory  (€81.84 @ Paradigit)
Storage: Corsair MP600 CORE XT 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€134.90 @ Amazon Netherlands)
Video Card: PowerColor Hellhound Radeon RX 7900 XT 20 GB Video Card  (€772.95 @ Megekko)
Case: Phanteks Eclipse G360A ATX Mid Tower Case  (€103.90 @ Amazon Netherlands)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€134.90 @ Amazon Netherlands)
Total: €1868.38
Generated by PCPartPicker 2024-02-06 17:20 CET+0100
https://linustechtips.com/topic/1556756-my-first-build/#findComment-16311132
https://nl.pcpartpicker.com/list/qtjsWt
7800x3d + 7900xtx + 32gb 6400c32
Pretty much the best thing you can get for a hair under 2000€
Manually set ram freq to 6000 so you dont have to bother stability testing and whatnot, can run these to 8800+ if neccesary for future cpus due to being hynix a die based (basically enable xmp and set the ram frequency to 6000 and you are good to go)
Board will handle an overclocked 7950x and it has 14 usb a ports (6 rear 8 internal) + 2 usb c (1 rear 1 internal) and do 8000+ 9000+ ddr5 easy so dont worry about the board not being good enough cause the b650m hdv is ridicolously overbuilt, and hey looks like my predictions for the desktop apu imcs likely being really good just like they were for previous gens (renoir 4400-4600 ddr4, cezzane 5000+ ddr4 1:1 fclk) wasnt wrong
https://linustechtips.com/topic/1556756-my-first-build/#findComment-16311205
