Fan type
Yep I am planning on using a AIO for my CPU. But my main concern is the air intake. Given the setup, do you still recommend on using an AF fan rather than SP fan?
Yes, AF fans should be enough. Depending on how many storage drives you have in your case you can take out the empty ones (the metal drive bays). Storage drives themselves don't get very hot (usually not above 36-37°C). If you're still concerned you could change one of the AF fans in the front with a SP fan and place it where you have your HDD installed. But it shouldn't be necessary to use SP fans for intake (except when a bunch of HDDs block the airflow; like in a Corsair 230T or any other case where the drive cage is in front of a single intake fan).
You can take a look at this thread where @NZXT-Eric responded to another question about the H440 and temps.
http://linustechtips.com/main/topic/105917-considering-the-nzxt-h440-worried-about-cooling/
