Help picking cooler
Go to solution Solved by Hinjima,
9 minutes ago, NukoTi said:
Id save the cash, so any good dual tower cooler is good? Like the deepcool
As I mentioned in my first post.聽 The Peerless Assassin SE 120 is the best bang for your buck.
The AK620 is also very good, a bit more expensive but it does look better.
Whats a good cooler for a 7 5700x, i used to have a mini pc build but im not comfortable having the cou idle 50-60 when im doing absolutely nothing and maxes out at 88 when i do some 3d rendering and i do alot of 3d rendering. Idk if i should go for an aio or a tower cooler yet
https://linustechtips.com/topic/1556314-help-picking-cooler/
Peerless Assassin SE 120 will be plenty 馃檪
https://linustechtips.com/topic/1556314-help-picking-cooler/#findComment-16308076
The Peerless Assassin 120SE manages to keep even the 5800X3D under control, so 5700X will be a walk in the park for it.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend聽|
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 |聽Sapphire Nitro+ RX 6900 XT |聽Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro|聽Phanteks Eclipse G500A |
https://linustechtips.com/topic/1556314-help-picking-cooler/#findComment-16308482
https://linustechtips.com/topic/1556314-help-picking-cooler/#findComment-16308486
Or if you really wanna overcompensate, you can take a trip down memory lane with this monstrosity - Le Grand Macho RT.聽
Thermalright Le Grand Macho RT Review - Finished Looks | TechPowerUp
https://linustechtips.com/topic/1556314-help-picking-cooler/#findComment-16308510
