What are good temps for a Ryzen 9 7900x?
Solved by Hinjima,
5 minutes ago, KPmine1 said:Hi! :3聽
I'm new to PC building and my friend said to post here if I ever have a question but what are the normal temps for a聽9 7900x? I'm using a 3 fan deepcool LS720 SE on top of my case with liquid metal thermal paste in a nzxt h7 flow case and i get idle temps of 35-41 degrees and around 60 to 65 when I play games like AC Odyssey.聽
Thanks in advance! :3
The temperatuers you are reporting are good temperatures for a Ryzen 9 7900x.
The 7000 series from AMD is actually designed to run at 95c 24/7 and anything under that is just a bonus.
You have good temperatures and nothing to worry about
