Which fans are better?
Solved by SpookyCitrus,
The ones that came with the AIO are going to be high-pressure fans designed to push/pull air through the radiator. The ones that came with the case are most likely just standard case fans. If you're wanting to know which ones to use with the AIO, stick with the ones it came with over the included case fans.
Featured Topics
Bobzcpu ·
Posted in Power Supplies0 -
Magnumenforce ·
Posted in Phones and Tablets1 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
