Need help building a NAS :)
Go to solution Solved by filpo,
26 minutes ago, Buckyy said:
12100F
you should get an igpu so a 12100
How much storage would you like?
Budget (including currency): £1000 GBP (Ideally)
Country: United Kingdom
Games, programs or workloads that it will be used for: NAS server for Family Pictures/Videos and Media Server
I am currently referencing Linus's video on building an affordable NAS server, I like the idea of availability for upgrade later on.
I want to create an Intel version if possible, only reason is that I currently have an Intel Core i3 12100F just laying around and would like to use that.
However, if upgradability is less likely on an Intel based system then I guess I will go AMD base.
Any ideas are greatly appreciated.
I know I said £1,000. That is my max as Linus managed to get an AMD system setup for under $700 🙂
Thanks all!
Josh
FYI: you don't need 16gb of ram but they're so cheap you might as well, and a modular psu for the last one to help with cables
and you could get a 512gb or 1tb ssd on top if you want
here's one: KIOXIA EXCERIA G2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (LRC20Z001TG8) - PCPartPicker
Here's one with 16tb
PCPartPicker Part List
CPU: Intel Core i3-12100 3.3 GHz Quad-Core Processor  (£110.82 @ Amazon UK)
Motherboard: ASRock B760M-ITX/D4 WiFi Mini ITX LGA1700 Motherboard  (£147.04 @ NeoComputers)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£34.99 @ Amazon UK)
Storage: Seagate Barracuda Compute 8 TB 3.5" 5400 RPM Internal Hard Drive  (£150.99 @ Amazon UK)
Case: Fractal Design Node 304 Mini ITX Tower Case  (£77.37 @ Ebuyer)
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply  (£56.95 @ Amazon UK)
Total: £729.15
Generated by PCPartPicker 2024-01-29 18:55 GMT+0000
And one with 20tb
Storage: Seagate Exos X16 10 TB 3.5" 7200 RPM Internal Hard Drive  (£179.00 @ Amazon UK)
Power Supply: Corsair RM650 (2023) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£74.99 @ AWD-IT)
Total: £803.21
Generated by PCPartPicker 2024-01-29 18:56 GMT+0000
Thanks all!
Josh
https://linustechtips.com/topic/1555334-need-help-building-a-nas/
12100F
Thanks all!
Josh
Total: £729.15
And one with 20tb
Total: £803.21
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Total: £729.15
And one with 20tb
Total: £803.21
Great suggestions, thank you. If I was to take a 128GB harddrive and wack an os on it, then remote desktop to the system, would I not just use the CPU I have got?
And 20TB is probably enough for now but I would probably want 100TB later on down the line
You'll need a GPU of some sort I believe - mostly for installing an OS. Do you have a random one laying around - GTX 650 or something old like that? You could throw that in for a display out.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
Yeah I have got an XFX RX 480 I can chuck in there for install, will I need to keep it in there? Or can I remove it after install?
23 minutes ago, Buckyy said:
128GB harddrive
you'd use an ssd
Motherboard: ASRock Z690 Pro RS ATX LGA1700 Motherboard  (£144.92 @ NeoComputers)
Storage: Patriot P300 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£30.99 @ Amazon UK)
Storage: Seagate Exos X20 20 TB 3.5" 7200 RPM Internal Hard Drive  (£322.99 @ MoreCoCo)
Case: Cooler Master Force 500 ATX Mid Tower Case  (£58.89 @ Amazon UK)
Total: £990.76
Generated by PCPartPicker 2024-01-29 19:30 GMT+0000
if you still want display you'll need to keep it there, so yes
then chuck that into the build above (which has 40tb and 5 sata ports for future upgrades as well as bigger case to 100tb)
Total: £1040.95
You can remove it after install if you don't need a GUI for anything. I don't know what OS you're planning to run, but if you're happy doing CLI only that should work fine.
I will be running TrueNAS so shouldn't be a problem
