High density front panel connector?
3 minutes ago, porina said:I recently got an Acer OEM mobo cheap and now I'm working through its quirks. One is the front panel header has pin density tighter than that commonly found on consumer tier mobos. Look at that... whatever it is connector to the right, that's the normal enthusiast connector spacing. Anyone know if there is any adapter available for the high density connector as I'm guessing enthusiast cases wont connect to it. I'm currently using the screwdriver method to power it on but at some point would like to get it in a case.
BTW I've only seen the high density connector twice. On this Acer mobo and another time on a HPE server mobo. Seems to be an OEM thing.
Looks like the same pin pitch that laptop IDE used back in the day. Are they 2mm instead of the normal 2.54mm? If so you should be able to get some jumper cables with the right size Dupont connectors on each end and roll your own adapter.
https://www.amazon.com/uxcell-Connector-Ribbon-Female-Length/dp/B07FKLKM7L
https://www.amazon.com/Fielect-Connector-Conductor-Electrical-Equipment/dp/B081N3H657/
