There is low pitched pulsing hum sound coming from either my CPU cooler, HDD or fans......... bass-like pulsing or "whom whom whom whom" sound
Solved by emosun,
Just now, xxRainzeroxx said:There wasn't a whom whom sound before I replaced the PSU. So I don't think it has something to do with bad bearing.
well modern computers don't have a lot of moving parts and if the noise is loud enough to be considerably audible then it's going to be due to a moving part.
theres a high likelihood that removing the fans from the system will result in the noise magically disapearing so I'd probably start with the fans
