Computer will not post
Solved by SImoHayha,
9 minutes ago, VeroVex said:@SlmoHayha i changed over to my 3200g, and have display when connected to my motherboard. Fans are not spinning on my gpu (rx580) but the blue power light is on. Still no display from gpu when booted into windows
sounds like the RX 580 is goofed then my friend. Unless there is a serious driver issue. But it sounds like it borked perhaps. You could try reinstalling some new drivers for it and see if it works and uninstall currnet drivers with DDU software
