Keychron K10 Pro Switches and Keycaps compatibility
As long as you have one of the hotswap versions of the K10 Pro you are good.
K Pro switches and most cherry MX style switches (~95% of switches out there, NOT hall effect, optical or low profile though) are compatible. The custom keyboard community has large standardized around Cherry MX compatibility, even if they look different on the top, if it says Cherry MX compatible you are good. Only thing might be 3pin vs 5pin, but the K10 Pro is compatible with both according to their website.
Same goes for keycaps, they should be compatible with all cherry MX style caps (i.e. using the + shaped stem, even if there's a bracket like [+] it should work).
The only thing to look for is to make sure you have indeed the hotswap version of the board and not the soldered one.
