Budget (including currency): max is 700
Country: United States
Games, programs or workloads that it will be used for: Fortnite, Minecraft, Call of duty, etc...
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Within the next few days I will be buying majority of parts, using a old hard drive from old computer for windows and moving it to the new ssd. He already has a monitor that runs at 1080p, and has a keyboard/mouse.
I really just need a second and/or third opinion about the parts list, if it's better to pay around the same price for a better but used graphics card, and if  3600 ram with 18 cas latency or 3200 ram with 16 cas latency is better?
https://pcpartpicker.com/list/q94KN6
https://linustechtips.com/topic/1551477-brothers-pc-build-help/
I'd stick with 3200 cl16 on am4
try this
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: *ASRock B550 Phantom Gaming 4/ac ATX AM4 Motherboard  ($89.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($54.97 @ Amazon)
Storage: Leven JPS600 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($76.47 @ Amazon)
Video Card: *ASRock Phantom Gaming D OC Radeon RX 6600 XT 8 GB Video Card  ($239.99 @ Newegg)
Case: *MagniumGear NEO AIR (2023) ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: *Apevia Prestige 600 W 80+ Gold Certified ATX Power Supply  ($51.99 @ Amazon)
Total: $703.39
Generated by PCPartPicker 2024-01-07 02:27 EST-0500
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1551477-brothers-pc-build-help/#findComment-16274320
