My pc turns on but no display, i checked the ram, the psu, i checked and switched the hdmi, but nothing worked. Can it be a problem if i had my heater on and my room was hot and it overheated the cpu or gpu or anything ?or is it just my gpu acting dumb.
Specs-
Ryzen 3 2200g
Rx 570
12gb ram 3000mhz
600w psu
1tb ssd
Motherboard-prime b450m AII
Im upgrading soon but in the meantime this is all i got
https://linustechtips.com/topic/1550612-help-with-pc/
Specs-
Ryzen 3 2200g
Rx 570
12gb ram 3000mhz
600w psu
1tb ssd
try booting windows off of another drive if you have
https://linustechtips.com/topic/1550612-help-with-pc/#findComment-16268801
Specs-
Ryzen 3 2200g
Rx 570
12gb ram 3000mhz
600w psu
1tb ssd
Try removing the RX 570 and booting off the integrated GPU. The Ryzen 2200G has a gpu.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1550612-help-with-pc/#findComment-16268808
6 minutes ago, Ineedhelpwithpcmyppls said:
So plug my hdmi into the motherboard ? Instead of the gpu ?
Yes, but the 570 needs to be taken out of the PC.
https://linustechtips.com/topic/1550612-help-with-pc/#findComment-16268820
