power cable to big
Go to solution Solved by OhioYJ,
23 minutes ago, bulletmuncher said:
(ie: a cable with a 90 degree head on it, if that makes sense)
Cable mod makes custom cables with a 90 degree plug (head as you called it) on them. Not to be confused with the 90 degree and 180 degree adapters that they are recalling. The custom cables do not have any known issues.
hey guys so ive just finished building a new pc with a ROG strix 4080 in it, but after finishing the build ive noticed that the power cable sticks out of the case slightly in a way that makes it so I can't shut the side glass panel. so I was just wondering if there was any other cables I could buy to potentially fix this issue (ie: a cable with a 90 degree head on it, if that makes sense)
thank you.
https://linustechtips.com/topic/1550280-power-cable-to-big/
https://linustechtips.com/topic/1550280-power-cable-to-big/#findComment-16266735
