Hello !
hope that I’m in the right topic but I had a question regarding my fan layout in my pc.
I currently got 1x200mm Noctua fan as intake in the front and a 120mm Cooler Master fan in the back as exhaust, I also have 2x 120mm NZXT fans as exhaust in the top but I’m not sure if I should flip those 2 around to use em as intakes.
would greatly appreciate some advice <3
https://linustechtips.com/topic/1549595-fan-layout/
15 minutes ago, Powerrangerjos said:
Hello !
would greatly appreciate some advice ❤️
What case?
I'd say leave them as exhaust in the furthermost back they can go.
Do you have room on the bottom to add a fan?  If so, I'd do 1 of each then.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1549595-fan-layout/#findComment-16262439
1 minute ago, Dedayog said:
What case?
It’s a pretty old case, it’s the Cooler Master 690 III (3) there might be some room on the bottom but the cables/connectors of the power supply would hover over the fan.
https://linustechtips.com/topic/1549595-fan-layout/#findComment-16262445
1 minute ago, Doggy_Dieter said:
I think you have got too much exhaust. You should do one more for intake on the bottom but an intake fan on the top is not that efficient
I’ll pull one of the 2 exhausts from the top and put it on the bottom
thanks for the advice everyone !
https://linustechtips.com/topic/1549595-fan-layout/#findComment-16262483
The ultimate decider is what gets you the best temps. If that means one fan in and one fan out on top, that's the best. Every build has different possibilities.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1549595-fan-layout/#findComment-16267951
If you found yourself having dust problems and/or are using dust filters, I will suggest making a positive pressure system, where more fans are pointing inward than outward. However, it won't really work unless you have no empty space left on the case (e.g., populate every single fan mount, or tape/seal off openings like extra fan mounts or unused PCIe slots)
(don't worry about what I just wrote)
That is a fairly old case. While I am a fan (ha) of 5.25 bays and lots of 3.5 sleds, I don't think most people nowadays would need any of that.
It has a side vent. Mount a 120 on the side .. ?
I feel like it's going to get cleaner (and fresher) air on the side, but if you find it annoying or impossible, then yes, top exhaust and bottom intake. Blow some fresh air toward the PCIe area.
https://linustechtips.com/topic/1549595-fan-layout/#findComment-16268624
