Budget (including currency): $600 USD
Country: U.S.
Games, programs or workloads that it will be used for: Halo Infinite, Half Life VR, PvZ GW2, The finals
Other details -
Already have a core I5 12400 system with a 2070 super
I’m planning to upgrade my gpu and maybe cpu however my budget is limited, I wonder if I get a 4070 for a gpu would my I5 bottleneck it?
https://linustechtips.com/topic/1549331-system-overhaul/
Country: U.S.
Other details -
Are you playing in 1440p or 1080p?  At 1440p, it's a solid upgrade.
The 12400 isn't a bad CPU for gaming so will be able to feed the 4070 decently.  I'd probably want to upgrade the CPU as well soon too though.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1549331-system-overhaul/#findComment-16260600
I have a 1440p monitor and I mostly play games at 1440p right now and they don’t run half bad but stuttering is an issue, Do you think I should upgrade the cpu before gpu? There is a 12700kf at a local store for $200 USD if that’s worth it or if the 12400 should be fine for now?
https://linustechtips.com/topic/1549331-system-overhaul/#findComment-16260672
What is the rest of your system?  PSU, drives, RAM, etc?
The 12700K at 1440p won't give much lift, maybe 10-15%.  I'd not get that for $200, personally.
Look at your drives, for stuttering.  Do you have any games on a hard drive?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1549331-system-overhaul/#findComment-16260679
No games on hard drives, Most are on an M.2 from SKhynix one or two old ones are on a SATA SSD drive from Inland. Stuttering has been a problem on some games especially in older ones and I’ve tried to fix, no throttling yet some older games are at 100% CPU all of the time
my Entire current system is as follows -
I5 12400,
Gigabyte B660 Gaming X AX DDR4,
32gb of G.skill 3200 mhz, (dual channel
Founders Edition RTX 2070 Super
Thermaltake Contac 9 SE cooler
4 Montech 120mm Fans
1 ASUS TUF gaming tf120 120mm fan
Corsair CX 750m PSU
SKhynix 256gb M.2
Inland SATA SSD 256gb Gold Drive
Montech X1 Mid Tower CaseIMG_1308.thumb.jpeg.ed1d77a454cdf5d651de3d2584d95022.jpeg
https://linustechtips.com/topic/1549331-system-overhaul/#findComment-16260746
A 4070 will certainly be an upgrade over a 2070, BUT be prepared to experience CPU bottlenecks soon with that 12400f on DDR4. The difference between DDR4 and DDR5 in average FPS isn't big, but in some cases the 1% and 0.1% lows and frame timings are really noticeably different where you would start to feel the gameplay more jittery or laggy and not that smooth as expected. And things will only get worse if you try to use DLSS.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1549331-system-overhaul/#findComment-16260836
