I need help building a pc
7 minutes ago, SOROBIN said:Budget (including currency): 1500 USD
Country: US
Games, programs or workloads that it will be used for: Gaming and general use
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I've made pcpartpicker lists for this, and asked some friends but i'm still worried about it, I have(in the list as i'm sending this) a AMD Ryzen 7 5800x, a Gigabyte gaming OC Rev 2.0 RTX 3070, 32 gigs of ddr4 ram at 4000 mhz(g.skill trident), and 1 tb of storage. I mainly just need help with bottlenecking and pricing, as I'm still worried about both.
Thank you to all who help.
I forgot to add and I added this after editing; i have a 240hz 1080p monitor
For future reference, when giving a parts list, add the PCPartPicker permalink at the top of the website rather than just screenshots.
Either way you can do much better for a system of this price: https://pcpartpicker.com/list/6Rq9n6
- The 7800X3D is an order of magnitude faster of a GPU.
- The AIO is very expensive and you can get by just fine with an air cooler.
- The B650M DS3H is a more budget motherboard, but it's also very well reviewed and can power a 7950X, so I wouldn't really worry about it.
- The RAM is the optimal speed for Ryzen 7000.
- You don't really need a 980 Pro for a gaming system, and for the same price you can get a 2TB drive instead.
- The H7 Flow is very similar looking to the Corsair 4000D, and the 4000D is very well reviewed and $30 cheaper, you might as well go for that instead.
- The PSU is the same price but a higher wattage while still being pretty well reviewed. Might as well get that instead.
- $400 for a 3070 is insane, especially considering how a 4070 is ~$100 more and significantly faster. Given you can fit a 4070 in the budget, get that instead.
- The P12 RGB are better fans than the NZXT ones while being significantly cheaper.
