CPU Exhibiting odd behavior under load
TLDR:
It seems to be a power draw issue. These components seem to be drawing more power than my 130w PSU can supply from the wall without supplements from the battery. See my explanation below for more info.
Update on the situation:
- After installing Aida 64 it looks like under load the CPU does turbo up to around 3.00 Ghz (this is not its maximum but given later edits I believe this makes sense)
- My CPUz benchmark scores are slightly under what I expected based on comparison data online. but the CPU still clocks high enough.
- I have been able to replicate the previous behavior in Valorant spesifically.
Based on testing from points 1 & 2, I noticed predictable and normal behavior from my system when under synthetic loads such as the mentioned Aida 64 and CPUZ. However when in a CPU bound game like Valorant, the issue still persisted. I began to suspect a power draw issue as my GPU might be taking power budget away from the limited 130W PSU that shipped with the unit. As my settings turned to low, I saw a noticeable improvement in my framerate consistency aswell as CPU clockspeed and CPU usage. The higher the GPU demand with quality turned up to medium, I began to see the same issues of low clock speeds underload and large dips in framerate. Under sustained high fps limits in game i began to see large dips in FPS like before again.
From the looks of it, I believe the issue is the powersupply is insufficient for these components to clock to higher speeds, as this is only a 130w unit.
Further testing is required as it could be a dell low power mode that was engaged when the battery was disconnected (this needs more testing), and a higher wattage PSU (180w) needs to be tested before any true final conclusions are made.
Thank you so much to everyone who responded it helped so much! I will also continue to test as I would like this laptop to be a backup/secondary gaming laptop for myself or friends.
