Hi,
I would like to ask you if this £600 budget gaming pc build will  be good for running games on max settings. This is my first build meaning that I don't know if i could make any improvements within my budget. If you think I can improve anything please tell me.
Gigabyte G1.SNIPER Z87
Intel Core i3-4330
Corsair CX600M
Western Digital 1TB HDD
MSI AMD Radeon R9 270X
GSkill 8GB (2 X 4GB) Ripjaws X DDR3 RAM
CM Storm Scout 2
Thanks in andvance,
Dawid
https://linustechtips.com/topic/154863-my-first-build/
Hi,
Intel Core i3-4330
Corsair CX600M
CM Storm Scout 2
Thanks in andvance,
Dawid
You don't need a z87 board if you don't have a K cpu so get a b85 board (something like a Gigabyte G1.Sniper B5) and swap the i3 for a i5 4440 or even a 4570
For the psu a 500w will be fine.
https://linustechtips.com/topic/154863-my-first-build/#findComment-2064358
pretty poor heres a better one
1. you were going with a duel core that cant be over clocked in a over clocking motherboard
2. 270x isnt the best but it will do
use the quote button if you want my help
also im assuming your from the uk
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£104.72 @ Aria PC)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  (£98.47 @ Amazon UK)
Storage:  Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  (£32.90 @ Amazon UK)
Video Card:  EVGA GeForce GTX 770 2GB Superclocked ACX Video Card  (£255.98 @ Dabs)
Total: £685.74
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-20 09:58 BST+0100)
Specs
https://linustechtips.com/topic/154863-my-first-build/#findComment-2064359
Total: £685.74
SSD's have dropped in price I would chuck one in as they are worth it, this is a great build and a lot better.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/154863-my-first-build/#findComment-2064367
https://linustechtips.com/topic/154863-my-first-build/#findComment-2064368
@dawidzjaja you cant run in max settings 1080p with that budget
Why are you getting a z87 mobo with a non OC cpu (i would get an amd cpu with that budget)
You dont need a 600W PSU something like 500 is plenty
I agree!
BUT: With the Z87 board, he will have better upgrade possibilities in the future: i5/i7 unlocked. Although, in case that is not the plan, go with something cheaper!
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/154863-my-first-build/#findComment-2064369
