Power a 5G CPE router in the car
Solved by TimedPing,
Buck converter is sometimes can messing up your devices, the best thing you can do to ensure stable and clean 12V DC power is either hooking it up to a PD powerbank with DIY/premade PD 12V trigger board, or like me in the past, I just buy good car charger with 12V PD function and hook up to my DIY trigger board to request 12V signal to the charger, and adapt it to standard barrell jack (in this case I powering a DIY OpenWRT router with M.2 B key 4G module installed).
LTT reference video if you want to learn how it works (in entertaining way):
Here some refrence picture if you need it:
Car charger - make sure it can atleast deliver 12V at 2.5A (PD/PPS specs):
