Help with build Problems
5 minutes ago, MrPapaBear1984 said:CPU goes from 35C to around 90c no throttle shows there, so that’s good but still feels like a high temp.
It's high, but by 9900K terms not that high. I wouldn't really worry about it.
5 minutes ago, MrPapaBear1984 said:What concerns me is the vr thermal throttling that occurs about 1-2 min into the test. Did I oversee anything in the Bios or is this just a 370 board problem?
This is a problem, but it's a problem with the motherboard. 9900Ks draws quite a bit of power, so at full load the motherboard VRM will be pushing quite a lot of current. Most mid to lower end motherboards like the TUF Z370 aren't really designed to handle that amount of current, so they will run very hot and have to rely on throttling the CPU to prevent it from dying. That sounds like what's happening here.
Pointing a fan directly at the VRM should help as direct airflow helps quite a bit with temps.
