hey guys, in the height of the cpu price gouging a few years back i needed a decent card and was lucky enough to come across a zotac trinity 3090 for less than i could find 3070's so i jumped on it. now down the line i want to push it a bit further as this version isnt overclockable on the stock bios as far as i can tell. i added a eiswolf waterblock setup to the 3090 early on because the stock cooler had extremely annoying fans and in turn it will keep temps well under control and hitting max boost basically all the time...max boost is 1952mhz. i know some of the other 3090 bios offerings will have higher clocks out of the gate and be overclockable but i dont know which specific bios options i should look at. if anyone can lend a hand with that it would be much appreciated.
part 2
once finding an appropriate bios does anyone have a good tutorial to reference for flashing and getting everything dialed in?
Edit: runs stable max clock at 48C, could probably push the fans harder if needed.
https://linustechtips.com/topic/1547707-bios-flash-tutorials-and-guidance/
