I need to stop this but I need help on how
Solved by Alex Atkin UK,
29 minutes ago, yo i like pugs said:so my Wii U is yellowing but I don’t know how to remove the yellowing could some tell me how
You can't stop it, only potentially reverse (mileage may vary) it which would mean completely dismantling it as you need to treat the plastic with chemicals you want nowhere near the electronics.
It will yellow faster if its subject to daylight though.
This is why I bought the black model.
