Ive been running my Ryzen 7 5700G with a NH-D15 for a year now, on a constant Voltage of about 1.45625 Volts and 4675Mhz 25Mhz over the stock specs, and never thermally managed to get it to Thermal throttle, max temps ive seen were ~85°. now ive come up on a video from Techquicky, saying, undervolting with the same performance with less power usage and all that stuff, how does that look in my case? i dont really necessarly use my cpu at 100% mostly, just 30% or more for game loading. none of the programms crashed with these clocks & voltages, but I kinda started to worry, about the lifespan. the internet is telling me to stay under 1.45v, some telling me 1.5v with good cooling is "safe", im really just confused. can a expert, or a experienced person tell me, whats good, what bad for this config of a overclocking?
https://linustechtips.com/topic/1546974-cpu-overclocking-long-term-negative-effects/
With temps controlled as they are, it's probably fine as it is; it seems like a waste of power for 25Mhz over stock, though. It would be better to use the PBO2 auto overclock feature in Ryzen Master (or bios), you can set it to boost 200 MHz over stock to both increase performance and save power when you aren't boosting.
You're probably confused because your sample size is..... one. So yeah that's going to produce some wildly conflicting information.
then don't overclock it. return to stock speeds seeing as you aren't actually using the cpu enough to even get close to it's maximum stock speed.
Games will load 1-8+ cores to 80-100%, most tend towards the lower end so total CPU usage will appear low, but the chip is boosting to full clocks and games will see gains from the cores running faster.
That said, typically a 200Mhz+ boost is what's noticeable to the end user without a bunch of careful benchmarking and comparing single digit fps differences, so I'm going to echo @NikolakiH on that being a waste of power for an imperceptible boost.
From what I have read you do not want to run 1.45v or higher as a constant voltage on these Ryzen chips. I believe it was due to current draw or something, when running stock they do pull that voltage or higher, but usually not under heavy load (voltages will drop back down when running auto). I don't have much experience overclocking anything past Zen+ (where the limit was 1.4v or so, if memory serves I ran 1.425v early on but that was later discovered to degrade the Zen/Zen+ chips slightly) so I can't personally confirm that. In general, overclocking most Ryzen chips seems useless unless you need the slight gains in allcore performance (as noted, your games are not loading all cores), as PBO will typically reach the same boost clocks on the cores games are actually using, and can often do so with less voltage than stock, keeping the chip cooler and safer.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Voltage alone wont do it, you need Amps to kill it, so with Temps controled and the Amps more or less under control its fine.
I was running my 3900x at 4.7 all core for some time and no issues.
My 5800x3d I have it on stock voltage but I let it eat all the juice it wants and I have the clock gen at 102 so it has more clock then stock all core. No issues, But I have a big water loop .
Amps come from the load, good thing you don’t work your computer very hard, 1.45 is a lot of static volts. Letting the board push to 1.5 is one thing, but you running it at 1.5 is bad. But I wouldn’t give a fuck about that cpu personally, so I would probably run it anyways.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
i mean, AMD cpus do run higher voltage on idle, than while usage, so i guess its fine on the other side, however, its as i mentioned, fix voltage of 1.45v and when i load the cpu, it stays 1.45v but do get higher cinebench score and like ~15% more game performance. so is it safe to use this type of OC for like ~3 years?
