I need some help finding a power supply for my nephews computer.
The power supply I got based on pc part picker should have worked, but it only had 1 motherboard power cable and only the y cable version of the pcie power which was not good enough to run the system.
The power supply has to fit in the fractal pop xl air which has a bit of a tight fit. It also needs to have power cables that can power both a 3070ti and an ASUS ROG STRIX B650-A GAMING WIFI 6E.
I'm having a hard time finding a power supply that is 850watts, small enough to fit the case and has the correct power cables.
Any help is much appreciated!
Most boards will run fine with only 1 8 pin installed.
What do you mean by y cable version? 6+2 pin?
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
31 minutes ago, Dan Aran said:
fractal pop xl air
uses ATX power supply format, which is pretty standard,
you should be fine with either good 750W PSU or high quality 650W PSU, for example Gold rated Corsair RMe (or RMx) or Gold rated Thermaltake Toughpower
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
I'd recommend 700W+ PSU for headroom though
PC:
PCs I used before:
1 hour ago, will0hlep said:
Most boards will run fine with only 1 4 pin installed.
So this motherboard has the regular 24-pin, an 8-pin, and a 4-pin port. The power supply I originally got did not have the 4 pin cable. I am trying to have everything set up and connected, just in case if down the road my nephew wants to upgrade he does not have to get a new power supply.
image.png.f4f967ee690fd7a73bfe9f7f76a81956.pngThis type of cable is what I meant by Y cable
Is 700W+ enough for a 3070TI? I know the 3080TI needs at least 850W is it that far of a difference?
you could try only fitting the 8pin on the motherboard and leaving the 4pin not plugged, and see if that works, because I think it should, what's the CPU on the Motherboard do you know?
PC:
PCs I used before:
Full specs for the system without power supply are:
CPU: AMD Ryzen™ 9 7900X3D 12-Core
CPU Cooler: CORSAIR CW-9060058-WW iCUE H100i RGB ELITE
Motherboard: ASUS ROG STRIX B650-A GAMING WIFI
Ram: CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz
GPU: EVGA GeForce RTX 3070 Ti FTW3 Ultra Gaming
Case: Fractal Design Pop XL Air RGB
Memory Drives: SAMSUNG 980 PRO SSD 1TB and Seagate BarraCuda 4TB Internal Hard Drive HDD
____
I will try with the 8-pin alone and see if that works. Is the 700W enough for the above?
it's likely if you're not doing any CPU overclocking, do you know the model of the PSU?
PC:
PCs I used before:
Based on this I was thinking the new PSU could be the RM750x SHIFT 80 PLUS Gold Fully Modular ATX Power Supply. Either 750 or 850 watt. That give him wiggle room if he wants to upgrade down the line his gpu or something
Do you think that has the cables and power for this system?
More important question because of the location of the modular board 'is the PSU compatible with the case'?
The RM750x SHIFT 80 PLUS Gold Fully Modular ATX Power Supply should fit, I think. height is the only concern, but it seems thinner than other PSU. ‎11.6 x 9.5 x 5.2 inches
The extra 4 pin is only really for if you want to use a 7950X with a watercooling loop and overclock the hell out of it , It'll be perfectly fine with just the 8 pin.
I have some gripes with your component choice but it's too close to Christmas to fix and I'm sure he will be happy with it.
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
Thanks for the help, everyone!
I found a PSU that fits and works.
Well it did.. But it failed after 10 minutes of being on and then no power anymore. So getting it replaced and trying again.
What's the brand and model of this PSU?
  • 2 weeks later...
 Corsair RM850x Shift
