Wireless headset
shadowss
Hello im on the lookout for a new wireless headset since my logitech g pro x just broke after think 3-4 years (had them for a long time so cant remember how old they are)of use the little plastic thing holding it came open and cant close again could fix it with some tape but not sure how well that would be
would like to hear some recommendations since well as you can hear i have not shopped for wireless headset for a while and when i look at them seem like most people are recommending headset that are way more expensive than these was these were around 100 us dollars expecting to use a max of 150 us dollars
Do you require wireless?  Wired are far cheaper and open up a much larger world of options whether you go with a gamer headset or an audiophile solution.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
i know wired are far cheaper but at the same time i have gotten so used to wireless and find it much better for my usecase since usually when i buy wired i have to change it out every like 1-1 and a half years cause wire is broken
I understand, wireless has it's uses.  But if you get something with detachable cables and perhaps replaceable pads it will last longer than other wired options.
DAC S.M.S.L SU-9
again have tried detachable cables and headset with non detachable cables before many times and no matter what the cable always end up breaking even the charging cable on this headset is partially broken to the point where the metal is exposed so for me wireless is better and i also found it less annoying to not have a cable that goes infront of me or goes in the way constantly
so again im very sure i would want a wireless headset again for the simple reason for my usecase its just better and easier for me to take care of after all the amount of time i had this equal to the amount of time i usually had around 3 different other headsets
a thing there would also happen with headsets would be i would forget there was a cable or that i had a headset on and sometimes just yank out the cord or pull the cord tightly this has happen many times with other headsets never really happen with this cause well its wireless
For this kind of budget I'd just go for HyperX Cloud of some generation, I'm not huge on their sound but they are certainly reliable and until you reach Audeze Maxwell prices that's as good as you'll get wireless
can see that i could get a SteelSeries Arctis Nova 7 wireless for 129 us dollars where cheapest i could find of the hyperx cloud wireless would be hyperx cloud 2 and 3 wireless for 187 do you have any experience on the steelseries and would it be worth buying that instead maybe ?
I haven't tried many Steelseries headsets, but you do see too many posts on here and elsewhere about "My steelseries headset is dead" for me to be happy recommending them, there just isn't many good gaming headsets or wireless headphones out there
thats very fair i know how the cloud 2 sound cause i bought a pair for a friend as a gift some years back guessing the wireless ones does not sound different or much different than the wired and they would def be a lot worse than the ones i currently have but ill give it that hyperx usually are quite sturdy
i know a friend of mine have had steelseries headset for years but going off one person when it comes to choosing does not make me happy thats why i ask around what other people would recommend
