Hello
I want to gift my self a new pair of haidset, the Meze 99 classic, with a pretty and high quality cable. I will use it with my pc, mac and iphone.
i need help for adapters, i need to adapt the lightning to 4.4mm or 2.5mm jack female from the cable.
i thought of using the official lightning to jack adapter that is well recommend from audiophiles and then a jack adapter to 2.5mm jack also from Meze (MONO 3.5 MM OFC BALANCED UPGRADE CABLES)
thanks you
https://linustechtips.com/topic/1545342-i-need-help-for-audio/
5 hours ago, Clement_ctx said:
Hello
thanks you
Balanced cables are for balanced connections. They arguably do not make a performance difference - they're meant for reducing possible interference and giving you more gain (volume).
If your source is an iPhone, then you're just working with a standard, unbalanced 3.5mm jack (-to-Lightning adapter).
Don't upgrade cables. Waste of money. No performance difference. All placebo.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1545342-i-need-help-for-audio/#findComment-16234578
Okay, thanks you for the explanation, i didn’t understood the balenced things
https://linustechtips.com/topic/1545342-i-need-help-for-audio/#findComment-16235758
