Stars not showing in pygame zero
ff_Floris
Go to solution Solved by adm0n,
You have never called star1.draw(), so he will never actually be drawn.
I'd also recommend not creating the actor inside the draw routine. Rather create your actor globally and then only call star1.draw() in the draw routine.
(I'd also recommend not moving it once per draw :D)
Im making a simple game where you can shoot stars in pygame zero, but after a bit of time coding i ran the code, but i didnt see the stars. Is there any way to fix this? (please note that some of these things are temporarily and i will remove them later on in the project)
import pgzrun
import random
import pygame
WIDTH=800
HEIGHT=600
amount_of_stars=10
clicked=False
def draw():
    screen.blit("bg1",(0,0))
    star1=Actor("star")
    star1.pos=random.randint(0,750),random.randint(0,550)
def update():
    global clicked
    mouse_x, mouse_y = pygame.mouse.get_pos()
    if clicked==True and star1.collidepoint(mouse_x, mouse_y):
        clicked=False
    #star.pos=random.randint(0,750),random.randint(0,550)
pgzrun.go()
