7 minutes ago, CHUNGUSss said:
I have this clicking sound and its driving me insane. Do Any of you have an idea of why its sounds like that?
Sounds like something is rubbing on one of the fans.
Stop the fans one by one with your finger ( its safe, won't hurt too much ) and see what fan might cause this issue.
Could also be the AIO pump.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230498
72321309762__6D137EC5-8DDB-49ED-8020-2834F31E5AE5.MOV 883.99 kB · 1 download
I agree, either a fan hitting a cable or the AIO pump running dry.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230501
2 minutes ago, CHUNGUSss said:
What do i do if The AIO pump is Tinning dry?
Buy a new AIO unless your AIO has a refill port.
Just stop every fan with your finger to see if any of them are causing the issue before worrying about the AIO Pump.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230511
I have stoppet every fan. So it must be The AIO pump
You can do two things:
- you can use a volume (loudness) meter app on your phone and move your phone's microphone around to find where the sound is coming from. Did you stop the PSU fan too? The GPU fans? People forget those...
- check your temperatures. A dead AIO results in poor temperature transfer and usually the CPU overheats. Also, you can touch the tubes and the radiator to check how the temperature spreads.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230521
Its my friends pc and he says that it Also crashes sometimes While hes playing. And he Also says that when he has The glass panel on it crashes because of overheating.
i also Used a volume meter as you Said and when i took it next to The radiator the app Said it Got loud
so i belive it must be The AIO cooler thats The problem
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230535
Replace the cooler. At least put a stock/box cooler till something better is obtained.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230537
22 minutes ago, CHUNGUSss said:
Okay. Do you have any AIO Cooler recomendations for an Intel i9 11900f?
Why not get a nice AirCooler instead? Then this problem won't happen in the future, no pump failures on AirCoolers 🙂
The 11900f is not a very hot CPU.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230573
Budget?
Which case is the PC in, and what size AIO-s does it accept?
I'd put a Peerless Assassin 120 air cooler in there if it can fit.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230574
6 minutes ago, 191x7 said:
Budget?
Agree with @191x7 Peerless Assassin SE 120 will be more than enough for this CPU.
Just make sure it can fit in the case. We can double check for you if you know what case it is.
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230577
the case is 37,5 cm lenght | 38 cm height| 15,5 width
is that a big enough case for the Peerless Assassin SE 120??
https://linustechtips.com/topic/1544789-clicking-sound/#findComment-16230689
