Need help choosing GPU
Go to solution Solved by hatdz,
Then go for it, the R9 280 is actually faster than the GTX760, but if you need the Shadowplay feature, then by all means get the GTX760.
I don't need shadow play. sooo if the R9 280 is faster than thats what i will get
770 or 280x
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058222
I currently have  a AMD 7770 in my system. I have $300 AUD in the bank to spend on a new GPU. Which will get me the most FPS for my money?
If you're buying from an online site down under, please put a link tot the site......always willing to help someone else spend some cash. ;)  :D
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058238
I buy all my pc parts from these websites:
http://www.umart.com.au/umart1/pro/
http://www.pccasegear.com/
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058251
There are two (Modern) pairs of video cards that I can think of for that price (I think, if I'm converting it right). Either the GTX 760/r9 280, or the GTX 770/r9 280x.
From the threads I've seen comparing both cards, the r9 280 seems to be the recommended choice for the former pair, whereas the GTX 770 is usually the recommendation for the second pair. Then again, that's only from what I've seen. If I were you though, I'd shell out a few extra dollars for the GTX 770 or r9 280x. I think it's worth it in the long run. :)
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058261
 I am trying to get the new GPU before watch dogs comes out so that i can play it with good frames. In australia the R9 280x is $350 and the GTX 770 is $400
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058279
I was thinking about going nvidia this time sooo i might go for the gtx 760. If only there was something between a gtx 760 and a 770
BTW, the R9 280X is AUS $330 actually....
http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1559&products_id=25553
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058293
The the 760 is best on Nvidia, but the 280 is better. Maybe save the money to get the 280x, it's not that much more for a decent performance boost.
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2058314
Here's one of the few reviews which I can find that has the GTX760 vs the R9 280 benchmarks, so you can judge for yourself....
http://www.eteknix.com/xfx-r9-280-double-dissipation-black-edition-oc-3gb-graphics-card-review/
But if you can stretch your budget by another 10%, that is $330, the XFX DD R9 280X (link in my previous post) would be significantly faster than the R9 280 and GTX760. It comes with 3 games as well.......can't beat that!
Yep, that's what I'm suggesting to the OP, the R9 280X at AUS $330 is a very good buy, it's way faster than the vanilla R9 280......
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2059212
Shadowplay is overrated, a Core i5 with Dxtory will net you the same performance so long as you use RAID HDD's or a dedicated drive.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/154353-need-help-choosing-gpu/#findComment-2059217
