PC randomly shutting down when gaming. PSU problem?
Hi,
First off, english isn't my first language so there might be spelling mistakes.
My PC is crashing/shutting down when I am play games.
Games that have crashed: CS2, Overwatch 2 and Rocket League
Games that haven't: League Of Legends, Minecraft + multiple single player games
When my PC crashes, both of my screens turn dark, my RAM and motherboard RGB are still shining but no fans are spinning (including GPU fans). Nothing happens if I hold down the power button to turn it off, neither does pressing it. I have to turn off the PSU, wait until the RGB stop working, turn the PSU on and then I can start the PC. I saw someone bringing up the logbook, so I took some screen shots of it if it has any connection.
image.png.d8758b182b362b2ef325315156198ebe.pngimage.png.4b006e70f3aec81fea409808b387705e.png
Specs:
GPU =  6900xt
CPU = 5900x
PSU = 1000w bronze modular
RAM = 32 GB, 2x16 GB 3200 MHz and 2x16 3600 MHz DDR4
Motherboard = Asus Prime x570-P
It only crashes when I have played certain games for at least around an hour
I suspect the problem might have to do with the PSU. I've had it for around 1,5 years, maybe a bit longer, and I had bought it used. Does anyone know of a way to test if there's something wrong with the PSU? or does someone know if something else might be the problem?
Ty in advance!
What is the exact make and model of the PSU?
| Mark Solutions as Solutions | Just Because Nobody's Replied Doesn't Mean Nobody's Thinking | Refresh Often| Bottleneck Calculators are BS|
Main System: CPU: Intel Core i5-12600K/ COOLER: Be Quiet! Pure Rock Slim 2/ RAM: 32GB (2x 16GB) Corsair Vengeance LPX DDR4 3600MHz/ GPU: MSI RTX 3070 LHR Ventus 2x OC/ SSD1: 512GB NVMe M.2 SSD & SSD2: SK Hynix P41 2TB/ Case: Fractal Pop! Air (Black RGB TG Clear Tint)/ PSU: EVGA SuperNOVA 750 P2/ MOBO: AsRock Z690 Phantom Gaming 4
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-67 C (140-152.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 71-74 C (161.6-178.4 F)
Second System: CPU: Intel Core i7-4960x/ COOLER: Old Corsair 120mm AIO/ RAM: 32GB (4x 8GB) Corsair Vengeance DDR3 1600MHz/ GPU: AMD Radeon PRO W5700 GPU/ SSD: 250GB Samsung SATA SSD & HDD: WD Blue 500GB/ Case: Thermaltake Level 10 GTS/ PSU: Corsair RM1000X
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-65 C
GPU: Under Fur Mark for 45 minutes, temps reach around 69-73 C (156.2-163.4 F)
Laptop: Lenovo IdeaPad Gaming 3i 15IMH05 (Intel Core i5-10300H, 16GB DDR4 2933MHz, Nvidia GeForce GTX 1650 Ti, 500GB NVMe M.2 SSD & 500GB SATA SSD)
Temps under load: CPU: Under Cinebench r20 looped for 30 minutes, temps reach around 87-92 C (188.6-197.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 81-84 C (177.8-183.2 F)
NAS: I converted an older Advantech PC used for X-Ray machines to hold a hard drive or two. CPU: i7-6700 with whatever cooler was in the Advantech chassis/ RAM: 32GB Generic DDR4-2666/ SSD: Samsung 250GB SATA SSD/ HDD: 2TB Seagate random HDD
Phone: iPhone SE 2 (2020 version)
8 minutes ago, Side said:
Heating and dust issue. Blow off dust in your pc and install a fan on top of cabinet. Change Ram Slots.
That could very well be the problem, haven't cleaned it in about 9-10 months now that I think about it. Don't have any canned air to clean it, so it'll have to wait until tomorrow. Thank you for the advice!
4 hours ago, Capt Bacon said:
Hi,
Specs:
GPU =  6900xt
CPU = 5900x
Ty in advance!
Allow us to apologize for any inconvenience being experienced at this time and we'll be happy to assist as best as possible. Are there any overclock (OC) settings being applied to any components? Also, are you able to recall an software updates done before this issue started?
You can also visit the following FAQ below to assist with the issue being experienced: https://www.asus.com/US/support/FAQ/1015440
