Hi, I recently set up a do-it-yourself makeshift security camera for my room (not facing inside the room by the way) using software called ContaCam by Contaware. It allows for clips to be uploaded to an FTP server that I set up on a different computer. The way that it organizes files by the year and month is fine, but after the month, it just throws everything in the same folder. I was wondering if there's some program that could automatically sort through the mix of .gif and .mp4 files that get dumped into that folder and organize them into separate folders either every time something new gets put in there, or at regular intervals throughout the day. I tried getting ContaCam to send those files to separate folders, but it didn't work. Does anyone know a program that can do this? Thanks!
Just in case:
System running ContaCam is a Lenovo Yoga 2 11 with an i3-4012Y, 4GB RAM, 500GB SSHD, Windows 10 Home
System running the FTP has an i7-4790, BIOSTAR B85 motherboard, 16GB DDR3, 250GB Samsung 850, 500GB HDD, 1.5TB HDD, add-in wifi card with AX200, PSU is an RM1000X, and OS is Windows 10 Pro.
| Mark Solutions as Solutions | Just Because Nobody's Replied Doesn't Mean Nobody's Thinking | Refresh Often| Bottleneck Calculators are BS|
Main System: CPU: Intel Core i5-12600K/ COOLER: Be Quiet! Pure Rock Slim 2/ RAM: 32GB (2x 16GB) Corsair Vengeance LPX DDR4 3600MHz/ GPU: MSI RTX 3070 LHR Ventus 2x OC/ SSD1: 512GB NVMe M.2 SSD & SSD2: SK Hynix P41 2TB/ Case: Fractal Pop! Air (Black RGB TG Clear Tint)/ PSU: EVGA SuperNOVA 750 P2/ MOBO: AsRock Z690 Phantom Gaming 4
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-67 C (140-152.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 71-74 C (161.6-178.4 F)
Second System: CPU: Intel Core i7-4960x/ COOLER: Old Corsair 120mm AIO/ RAM: 32GB (4x 8GB) Corsair Vengeance DDR3 1600MHz/ GPU: AMD Radeon PRO W5700 GPU/ SSD: 250GB Samsung SATA SSD & HDD: WD Blue 500GB/ Case: Thermaltake Level 10 GTS/ PSU: Corsair RM1000X
Temps under load: CPU: Under Cinebench r23 looped for 30 minutes, temps reach around 60-65 C
GPU: Under Fur Mark for 45 minutes, temps reach around 69-73 C (156.2-163.4 F)
Laptop: Lenovo IdeaPad Gaming 3i 15IMH05 (Intel Core i5-10300H, 16GB DDR4 2933MHz, Nvidia GeForce GTX 1650 Ti, 500GB NVMe M.2 SSD & 500GB SATA SSD)
Temps under load: CPU: Under Cinebench r20 looped for 30 minutes, temps reach around 87-92 C (188.6-197.6 F)
GPU: Under Fur Mark for 45 minutes, temps reach around 81-84 C (177.8-183.2 F)
NAS: I converted an older Advantech PC used for X-Ray machines to hold a hard drive or two. CPU: i7-6700 with whatever cooler was in the Advantech chassis/ RAM: 32GB Generic DDR4-2666/ SSD: Samsung 250GB SATA SSD/ HDD: 2TB Seagate random HDD
Phone: iPhone SE 2 (2020 version)
What do the files look like (as in the filename structure)?
And to what "separate folders" would you like to sort them into? All the mp4s in an "mp4" folder and all the gifs in a "gif" folder? Or create daily folders in which files created on that day are moved to?
I could create a Python script for you to do that once I find a few minutes to spare.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
