First boot does not work, second one does (laptop)
Go to solution Solved by Average Nerd,
39 minutes ago, JSIB said:
I have got a problem with my laptop (Lenovo LOQ 16APH8 82XUOO57MH) on every other boot.
Every single time I boot after shutting down my laptop using windows 11, the laptop tries to boot, the screen goes off and I can't press anything to change this.
If I then shut down the laptop using the power button, and restart it, it boots up fine.
I have noticed that on that first boot every time I can not go to the boot selector screen, the second boot always works in regards to that.
I think this has happened because of a driver update, because I did not have this issue at first.
I have searched online for potential things to troubleshoot, but I could not find anything that seemed to help me.
Also on the first boot it does NOT show a loading circle, but on second boot it does.
I would gladly appreciate if anyone wants to help, because this is an annoying issue.
You could check if there is a firmware update available in Lenovo Vantage, if yes, install it, maybe it fixes it.
Edited by JSIB
Additional info
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Folding rig:
CPU: i7 4790K 2x Xeon E5 2690 V3
RAM: 16GB (4x4GB) DDR4-2666
MB: Chinese X99 dual socket board
GPU 1: RTX 2070 Super
GPU 2: GTX 1060 3GB
PSU: Gigabyte P450B EVGA 600BR EVGA 750BR Gigabyte UD1000GM
Cooling: 2x Delta GFB1212VHG with PWM
OS: Windows 11 Home
The daily rig (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
PSU: 230W Power brick
OS: Windows 11 Home
The workshop "rig":
HP Elitedesk 800 G4 Mini PC (Core i3 8100T)
OS: Windows 11 Pro
Linux let me down.
Hello!
I have checked but there is not an update available at the moment, still thank you!
I will check again later
Maybe try resetting the BIOS to factory settings, sometimes that fixes things.
F@H-Stats
The Folding rig:
GPU 2: GTX 1060 3GB
OS: Windows 11 Home
CPU: Core i5 12500H
OS: Windows 11 Home
The workshop "rig":
OS: Windows 11 Pro
Linux let me down.
Hello!
  • 2 weeks later...
Thank you so much, there eventually was an update and this fixed it!
