Hello,
Im considering building a loop for my new pc build i was looking to get some guidance and help to make sure i have everything i need and it will work.
Here is my pc specs
EVGA 3080 FTW3 - Reusing my current GPU
ASRock z790 Nova
Core I7 14700K -- looking at using Kryosheet instead of paste
TG intel contact frame
64gb G.Skill Trident Z5 DDR5 6400MT/s
Corsair RM1000e
Phanteks NV7
12 Phanteks D30 Fans
Here are some of the parts im looking at for my loop, let me know your thoughts on these parts and anything else i need or dont need
1x Heatgun
1x Alphacool Core Hurrican 360mm XT45 HardTube Water Cooling Set (11993)
1x Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 with backplate (11943)
1x Alphacool NexXxos XT45 360mm (14166)
1x Alphacool NexXxos ST30 240mm (14344)
1x EKWB EK-CryoFuel Premix 1000mL
1x Alphacool Eisrohr PETG HardTube 13mm ID 16mm OD 60cm clear 4 pack (18514)
1x ASHATA 16mm bending kit
1x Corsair hydro X series xf ball valve
1x Marrteum G1/4" 3-way ball fitting extender connectors 2 Pack
1x Barrow G1/4" Composite plate filter
x1 PrimoChill 1/2in Rigid RevolverSX series fittings 12 pack
x2 Barrow G1/4" Male to Male mini extender fitting 4 Pack
I have attached some Ideas for the layout if you could give me some feed back on these as well. they arent the best photos i made them at work with MS paint lol
https://linustechtips.com/topic/1542663-1st-custom-loop-help/
9 minutes ago, DarkXBlaze said:
How much more do you think I would need I already assumed there would be a learning curve for bending the tube
no idea some people get it right a way some people can use feet and feet of tubeing 🤷‍♂️
just doing 90 degree bends its might not be too bad. i watch j2cents for videos on it.
Greg Salaza on youtube aslo did a video on it long time ago and he went thow alot of tubing.
Edited by thrasher_565
https://linustechtips.com/topic/1542663-1st-custom-loop-help/#findComment-16217666
  • 2 weeks later...
On 11/26/2023 at 2:30 PM, DarkXBlaze said:
Thanks for all the help and input!
I would go with config Option #1 but have the drain port on the OUT port on the pump, or one of the ports on the side mounted radiator.
Personally, I would use the bottom for top-to-bottom system airflow. Just fans, no radiator.
You can also consider flipping the side mounted radiator so the in/out ports are at the top.
Then have the pump directly feed coolant to the GPU.
Pump -> (Drain Port) -> GPU -> CPU -> Radiator 1 -> Radiator 2 -> Radiator 3 -> (Back to pump)
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1542663-1st-custom-loop-help/#findComment-16236726
