Hi there,
I currently have the following RAM
2 x 16gb Corsair Vengeance RGB PRO SL
Now these run a max clock speed of 2666MHz but my system supports 3600Mhz DDR4
First question is, is it worth upgrading my ram to get the max clock?
And if so. What should I upgrade to?
Budget is whatever it costs to get the best.
Many thanks in advance,
Josh
https://linustechtips.com/topic/1542040-need-help-with-ram/
1 minute ago, Buckyy said:
Just found out that the none SL RAM that I have actually runs at 3600MHz but the SL RAM doesn't... Is this correct? If so I can just get 2 more non SL sticks and run at 3600MHz, right?
Yes, you can.
Is it worth it?  Depends on what CPU and rest of system you have.
Short answer is no though, since you have 64GB RAM?  I'd run the 2x16 at 3600MHz and be done.  Unless you NEED 64GB?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1542040-need-help-with-ram/#findComment-16213746
Your RAM will not run at 3600 MHz by default, even if it supports it. You'll need to enable XMP in the BIOS (basically an auto-overclock)
Running four sticks is harder on the CPU's integrated memory controller than two sticks. So it may or may not be able to run at 3600 MHz with four sticks regardless. Some CPUs, like older Ryzen generations, are known to have issues with it.
https://linustechtips.com/topic/1542040-need-help-with-ram/#findComment-16213754
26 minutes ago, Dedayog said:
Yes, you can.
I do game development so 64GB helps with high level design.
I have tried to enable XMP but because only 2 of my RAM sticks support 3600MHz, it refuses to boot windows.
11 minutes ago, pienutt said:
why not try overclocking this one? you'd be amazed how high ram sticks can go sometimes
Overclocking what sorry?
https://linustechtips.com/topic/1542040-need-help-with-ram/#findComment-16213803
Manually setting the memory timings and speed in BIOS, instead of using XMP.
I doubt 3600 will really benefit you since you seem to need more raw RAM than super fast RAM.  Marginal benefit at best.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1542040-need-help-with-ram/#findComment-16213805
Yeah, that makes sense. As I said above, XMP is an auto-overclock. It uses a profile stored in the memory sticks to apply the necessary settings automatically. If you have different sticks, those settings are less likely to work for all of them. So the fallback is to manually overclock the RAM (probably not as high as 3600 MHz), or get four identical sticks.
https://linustechtips.com/topic/1542040-need-help-with-ram/#findComment-16213864
